HP Pavilion - 15-cd024ax Product Specifications
2EV55PA
AMD Quad-Core A12-9720P APU (2.7 GHz base frequency, up to 3.6 GHz burst frequency, 2 MB cache)
16 GB DDR4-1866 SDRAM (2 x 8 GB)
Video graphics
AMD Radeon™ 530 Graphics (4 GB DDR3 dedicated)
512 GB M.2 SSD
Optical drive
DVD-Writer
15.6" diagonal FHD IPS WLED-backlit touch screen (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s)
37.8 x 25.21 x 2.25 cm
Starting at 1.95 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
