HP Spectre x2 - 12-c052nr Product Specifications
Z8T48UA
Intel® Core™ i7-7560U (2.4 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB LPDDR3-1600 SDRAM (onboard)
Video graphics
  • Intel® Iris™ Plus Graphics 650 (up to 4.05 GB)
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
12.3" diagonal 3K2K IPS WLED-backlit multitouch-enabled edge-to-edge glass (3000 x 2000)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 1 independent headphone/microphone combo
29.39 x 20.71 x 0.77 cm (tablet); 29.39 x 20.71 x 1.32 cm (tablet and base)
0.76 kg (tablet); 1.13 kg (tablet and base)
65 W AC power adapter
4-cell, 41.58 Wh Li-ion
HP Wide Vision 5 MP Camera and HP IR Camera with integrated dual array digital microphone (front-facing); HP 13MP Camera (rear-facing)
Bang & Olufsen, dual speakers
HP Orbit; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant
Pre-installed software
Netflix
