This information applies to Sprout Pro by HP G2 and the Stop Motion app.
note:To capture frames automatically, turn on Auto Frame Grab. The Frame Grab Delay Time needs to be longer because you need to move the object into its new position each time while the delay time is counting down. It is not necessary to tap Frame Grab each time, as it automatically captures each frame.
Editing tool icon
Function
Hide: Hide or display the editing tools
Pen: Select color and line width when using an Active Pen or your finger to write on the selection
Effects: Rotate, reverse, change the opacity, or change the scale or size of the object
Duplicate: Make an identical copy of the asset or object
Font: Change font style
To Front: When using more than one object, move the selected one in front, or on top of the other(s)
To Back: When using more than one object, move the selected one to the back, or behind the other(s)
Delete: Delete unwanted asset, text, graphic, or other asset
