HP Pavilion - 15-cc009tx Product Specifications
2DP04PA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal FHD IPS BrightView WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s)
37.8 x 25.21 x 2.25 cm
2.12 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
FreeDOS 2.0
