Document ID: c05527749
Version: 1
Audio driver support for RS1 April Refresh
Release date : 25-May-2017
Last updated : 25-May-2017
DETAILS OF CHANGE
Provided software updates for Conexant HD Audio driver to fix a potential security vulnerability issue.
COMPONENT VERSION
From 8.65.186.50.A.1 to 8.65.186.51.A.1
REASON FOR CHANGE
A potential security vulnerability caused by a local debugging capability that was not disabled prior to product launch has been identified with current Conexant Audio driver version on HP Desktop PC. HP provided software updates for Conexant HD Audio driver to fix it.
IMPACT OF CHANGE
To remove Conexant HD audio driver local debug log. No function impact of change.
Components affected:
Conexant High Definition Audio Driver for DT
DATE OF CHANGE
Effective date : 01-May-2017
Hardware platforms affected : HP EliteDesk 800 35W G3 Desktop Mini PC, HP EliteDesk 800 65W G3 Desktop Mini PC, HP EliteDesk 800 G3 Small Form Factor PC, HP EliteDesk 800 G3 Tower PC, HP ProDesk 400 G3 Desktop Mini PC, HP ProDesk 400 G4 Microtower PC, HP ProDesk 400 G4 Small Form Factor PC, HP ProDesk 480 G4 Microtower PC, HP ProDesk 600 G3 Desktop Mini PC, HP ProDesk 600 G3 Microtower PC, HP ProDesk 600 G3 Small Form Factor PC
