HP ScanJet Scanners - Supported products for Silex
This document lists the supported HP ScanJet scanners that are compatible with Silex devices in Windows operating systems. HP's collaboration with Silex technology now enables you to connect and share an HP ScanJet scanner on a wired or wireless local area network (LAN) using Silex devices.
Supported scanners
Silex technology designed devices to work seamlessly with the following HP ScanJet scanners:
  • HP ScanJet Pro 2000 s1 Sheet-feed Scanner
  • HP ScanJet Pro 2000 s2 Sheet-feed Scanner
  • HP ScanJet Pro 2500 f1 Flatbed Scanner
  • HP ScanJet Pro 3000 s3 Sheet-feed Scanner
  • HP ScanJet Pro 3000 s4 Sheet-feed Scanner
  • HP ScanJet Pro 3500 f1 Flatbed Scanner
  • HP ScanJet Pro N4000 snw1 Sheet-feed Scanner
  • HP ScanJet Enterprise Flow 5000 s4 Sheet-feed Scanner
  • HP ScanJet Enterprise Flow 5000 s5 Sheet-feed Scanner
  • HP ScanJet Enterprise Flow 7000 s3 Sheet-feed Scanner
  • HP ScanJet Enterprise Flow N7000 snw1 Sheet-feed Scanner
  • HP ScanJet Enterprise Flow 7500 Flatbed Scanner
  • HP Digital Sender Flow 8500 fn1 Document Capture Workstation
  • HP ScanJet Enterprise Flow N9120 Flatbed Scanner
Supported Silex devices
HP tested their scanning applications with Silex devices on different Windows operating systems (Windows 7, Windows 8.1, and Windows 10). All features of the HP scanning application worked without any issues for the following Silex devices:
  • BR-300AN
  • BR-310AC
  • DS-510
  • DS-520AN
  • DS-600
Silex devices for HP scanners
The following table lists the compatibility of Silex devices with HP scanner models.
List of tested Silex devices for HP scanner models
Model
BR-300AN
BR-310AC
DS-510
DS-520AN
DS-600
HP ScanJet Pro 2000 s2 Flatbed Scanner
HP ScanJet Pro 3000 s4Flatbed Scanner
Support
For problems with Silex devices, contact one of the following emails for support:
More information
For more information about Silex technology, go to one of the following websites:
