Product Specifications for the HP DeskJet Ink Advantage 2675 All-in-One Printer (V1N02A)
Product naming
Model name
V1N02A
Connectivity
Ports
1 Hi-Speed USB 2.0
Wireless capability
Yes
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy resolution
Up to 600 x 300 dpi
Environmental
Acoustic power emissions
6.2 B(A)
Acoustic pressure emissions
48 dB(A)
Operating humidity range
20 to 80% RH
Storage humidity
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30ºC
Recommended operating temperature range (Fahrenheit)
59 to 86ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Memory
Integrated memory
Memory, maximum
512 MB DDR3; 256 MB flash
Mobile printing capability
Mobile printing services
Yes, Airprint
Networking
Network protocols, supported
Wireless Network Supported
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; Legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
89 x 127 to 215 x 279 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain paper, Photo paper, Brochure paper
Media weight supported (metric)
75 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
No
Physical dimensions
Maximum dimensions (W x D x H, metric)
424.97 x 547.7 x 248.77 mm (with Input & Output Tray/Extension extended)
Maximum dimensions (W x D x H, U.S. standard)
16.73 x 21.56 x 9.79 in (with input & output tray/extension extended)
Weight (metric)
3.42 kg
Weight (U.S. standard)
7.55 lb
Power
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz). Input voltage: 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz) (China & India)
Print cartridges
Number of print cartridges
2 (1 black, 1 Tri-color)
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed (black, draft)
Up to 20 ppm
Print speed (color, draft)
Up to 16 ppm
Print speed black (ISO)
Up to 7.5 ppm
Print speed color (ISO)
Up to 5.5 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer on selected HP photo papers and 1200 input dpi)
Maximum print area (metric)
215 x 355 mm
Maximum print area (U.S. standard)
8.5 x 14 in
Minimum print margin, top (A4)
3 mm
Minimum print margin, bottom (A4)
12.7 mm
Minimum print margin, left (A4)
3 mm
Minimum print margin, right (A4)
3 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Printer smart software features
Manual Duplex
Regulatory specifications
Regulatory model number
SNPRH-1602
Electromagnetic compatibility
2006+ A1:2009+ A2:2009, EN 61000-3-3: 2008, FCC CFR 47 Part 15 Class B; ICES-003, Issue 4 Class B; GB4943.1-2011 (CCC S&E -China), CNS 14336: 1999 & CNS13438 (BSMI-Taiwan), VCCI-2 (Japan), EAC (Russia); KCC (Korea).
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum system requirements for Macintosh
Mac OS X v10.12 (Sierra), v10.11 (EI Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Recommended Macintosh system requirements
Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Compatible network operating systems
Windows 10, 8, 7, Vista, XP SP3 or higher (32-bit only), Win Server 2008 R2 and higher (via the command line installer), Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite)
One-year limited hardware warranty
Country: Flag Serbia
