HP PageWide Pro 750, MFP 772, 777 - Connect fax to a telephone line
  1. Connect the telephone cable to the fax port (1) on the product and to the telephone jack on the wall.
    To reduce the risk of fire, use only No. 26 AWG or larger telecommunication line cord.
The product is an analog device. HP recommends using the product on a dedicated analog telephone line. If you are using a digital environment, such as DSL, PBX, ISDN, or VoIP, make sure to use the correct filters and configure the digital settings correctly. For more information, contact your digital service provider.
Some countries/regions might require an adapter to the phone cord that came with the product.
