    We are upgrading our website
HP PageWide Pro 750, MFP 772, 777 - Scan to a network folder
To set up scan to a network folder
  1. Open the EWS. For more information, see Open the EWS.
  2. On the Settings tab, click Control Panel Customization, and then click Quick Sets.
  3. Click (Add), for Type select Scan to Network Folder, and follow the onscreen instructions for adding a Quick Set profile for a network folder. When finished, click Next.
  4. In this page, follow the onscreen instructions for setting up the network folder, authentication requirements, and scan and file configurations. When finished, click Apply.
  5. In the settings page, follow the onscreen instructions for configuring scan settings, such as paper size and scan resolution. When finished, click Save.
To scan to a network folder
  1. Load your original print-side down on the scanner glass or print-side up in the automatic document feeder.
    For more information, see Load the scanner or Load the document feeder.
  2. Do one of the following:
    • On a 203-mm (8-in) control panel: Touch the Scan icon, the Network Folder icon, and then navigate to the network folder.
    • On a 109-mm (4.3-in) control panel: Touch the Quick Sets icon, and then select the Quick Set profile for the network folder.
  3. If prompted, enter the PIN.
  4. Verify or change the information in the Save As and File Name fields.
  5. Touch the preview area, and then touch Send.
Country: Flag Serbia
