HP PageWide Pro 750, MFP 772, 777 - View or change network settings
Use the HP Embedded Web Server to view or change IP configuration settings.
  1. Obtain the product IP (on the control panel dashboard, touch [Ethernet]).
  2. Type the product IP address into the address bar of a web browser to open the HP Embedded Web Server.
  3. Click the Network tab to obtain network information. You can change settings as needed.
