HP PageWide Pro 750, MFP 772, 777 - To print from a wireless-capable mobile device
Make sure you have installed a compatible printing app on your mobile device. For more information, visit the www.hp.com/go/mobileprinting website.
  1. Make sure you have turned on Wi-Fi Direct on the printer.
  2. Turn on the Wi-Fi connection on your mobile device. For more information, see the documentation provided with the mobile device.
    If your mobile device does not support Wi-Fi, you are not able to use Wi-Fi Direct.
  3. From the mobile device, connect to a new network. Use the process you normally use to connect to a new wireless network or hotspot. Choose the Wi-Fi Direct name from the list of wireless networks shown such as DIRECT-**-HP PageWide XXXX (where ** are the unique characters to identify your printer and XXXX is the printer model located on the printer).
  4. Enter the Wi-Fi Direct password when prompted.
  5. Print your document.
