HP PageWide Pro 750, MFP 772, 777 - Clear jams in the stapler
Use an HP online troubleshooting wizard.
If you have a problem with the stapler/stacker, get step-by-step instructions.
The HP online troubleshooting wizards may not be available in all languages.
  1. Carefully shift the printer and open the stapler door on the back.
  2. Gently pull on the cap of the stapler cartridge to release the cartridge.
  3. Pull the stapler cartridge out from the printer.
  4. Lift the green metal lever on the stapler base.
  5. Remove the sheet with the jammed staples.
  6. Close the green metal lever until it snaps into place.
  7. Insert the stapler cartridge into the printer until it snaps into place.
  8. Close the stapler door, and carefully return the printer to its original position.
