HP Color LaserJet Enterprise MFP M681, M682 printers - Replace the toner cartridges
Toner-cartridge information
This printer indicates when the toner-cartridge level is low and very low. The actual toner-cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges or check cartridge compatibility for the printer, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
The printer uses four colors and has a different toner cartridge for each color: yellow (Y), magenta (M), cyan (C), and black (K). The toner cartridges are inside the front door.
Item
Cartridge number
Part number
HP 655A Black Original LaserJet Toner Cartridge
Standard-yield replacement black toner cartridge
655A
CF450A
HP 657X High Yield Black Original LaserJet Toner Cartridge
High-yield replacement black toner cartridge
657X
CF470X
HP 655A Cyan Original LaserJet Toner Cartridge
Standard-yield replacement cyan cartridge
655A
CF451A
HP 657X High Yield Cyan Original LaserJet Toner Cartridge
High-yield replacement cyan toner cartridge
657X
CF471X
HP 655A Yellow Original LaserJet Toner Cartridge
Standard-yield replacement yellow toner cartridge
655A
CF452A
HP 657X High Yield Yellow Original LaserJet Toner Cartridge
High-yield replacement yellow toner cartridge
657X
CF472X
HP 655A Magenta Original LaserJet Toner Cartridge
Standard-yield replacement magenta toner cartridge
655A
CF453A
HP 657X High Yield Magenta Original LaserJet Toner Cartridge
High-yield replacement magenta toner cartridge
657X
CF473X
High-yield toner cartridges contain more toner than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
Do not remove the toner cartridge from its package until it is time to replace it.
To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the printer for an extended period of time.
The following illustration shows the toner-cartridge components.
    Figure : Toner-cartridge components
  1. Handle
  2. Imaging drum
  3. Protective shield
  4. Memory chip
If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
Information about recycling used toner cartridges is in the toner-cartridge box.
Remove and replace the cartridges
  1. Open the front door.
    Figure : Open the door
  2. Grasp the handle of the used toner cartridge and pull out to remove it.
    Figure : Remove the toner cartridge
  3. Remove the new toner cartridge from its packaging by removing the plastic end caps, removing the cartridge from the plastic bag, and then removing the orange protective shield. Save all packaging for recycling the used toner cartridge.
    Avoid touching the green imaging drum. Fingerprints on the imaging drum can cause print defects.
    Figure : New toner cartridge
  4. Hold both ends of the toner cartridge and rock it 5-6 times.
    Figure : Shake the toner cartridge
  5. Support the toner cartridge underneath with one hand while holding the cartridge handle with the other. Align the toner cartridge with its slot on the shelf, and then insert the toner cartridge into the printer.
    Figure : Install the toner cartridge
  6. Close the front door.
    Figure : Close the door
Country: Flag Serbia
