HP LaserJet Enterprise MFP M631, M632, M633 - Replace the toner cartridge
This printer indicates when the toner cartridge level is low. The actual toner cartridge life remaining can vary. The toner cartridge does not need to be replaced at this time. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
Continue printing with the current cartridge until redistributing the toner no longer yields acceptable print quality. To redistribute the toner, remove the toner cartridge from the printer and gently rock the cartridge back and forth about its horizontal axis. For graphical representation, see cartridge replacement instructions. Reinsert the toner cartridge into the printer and close the cover.
Toner cartridge information
Item
Cartridge number
Part number
HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge
Extra high-capacity replacement toner cartridge
37Y
CF237Y
HP 37X High Yield Black Original LaserJet Toner Cartridge
High-capacity replacement toner cartridge
37X
CF237X
HP 37A Black Original LaserJet Toner Cartridge
Standard-capacity replacement toner cartridge
37A
CF237A
Do not remove the toner cartridge from its package until you are ready to use it.
To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the printer for an extended period of time.
The following illustration shows the toner-cartridge components.
HP 37X/HP 37A
HP 37Y
1
Handle (HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge only) or indentation for picking up the cartridge
2
Memory chip
3
Imaging drum
Do not touch the imaging drum. Fingerprints can cause print-quality problems.
If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
Information about recycling used toner cartridges is on the toner cartridge box.
  1. Press the cartridge door release button to open the door.
    Figure : Open the cartridge door
  2. Pull out the cartridge drawer.
    Figure : Open the toner cartridge drawer
  3. Grasp the handle or indentation of the used toner cartridge and pull up to remove it.
    Figure : Remove the toner cartridge
  4. Remove the new toner cartridge from its protective bag.
    Figure : New toner cartridge
  5. Hold both ends of the toner cartridge and rock it 5-6 times.
    Figure : Rock the toner cartridge
  6. Remove the cartridge shipping cover.
    Figure : Remove the shipping cover
  7. Place the toner cartridge in the cartridge drawer.
    Figure : Install the toner cartridge
  8. Close the toner cartridge drawer.
    Figure : Close the toner cartridge drawer
  9. Close the cartridge door.
    Figure : Close the cartridge door
  10. Pack the used toner cartridge into the box that the new cartridge came in. Adhere the prepaid shipping label to the box, and return the used cartridge to HP for recycling.
    Figure : Recycle the used cartridge
