HP LaserJet M652, M653, E65050, E65060, E65150, E65160, MFP M681, M682, E67550, E67560, E67650, E67660 - Load paper to Tray 1
The following information describes how to load paper into Tray 1. This tray holds up to 100 sheets of 75 g/m2 paper or 10 envelopes.
  1. Open Tray 1.
    Figure : Open Tray 1
  2. Pull out the tray extension to support the paper.
    Figure : Pull out the tray extension
  3. Use the blue adjustment latch to spread the paper guides to the correct size, and then load paper in the tray. For information about how to orient the paper, see the Tray 1 paper orientation section below.
    Make sure that the paper fits under the fill line on the paper guides.
    The maximum stack height is 10 mm, or approximately 100 sheets of 75 g/m2 paper.
    Figure : Load paper
  4. Using the blue adjustment latch, adjust the side guides so that they lightly touch the paper stack, but do not bend it.
    Figure : Adjust the guides
Letterhead or preprinted paper
Image orientation
Duplex mode
Paper size
How to load paper
Portrait
1-sided printing
Letter, Legal, Executive, Statement, Oficio (8.5 x 13), 3 x 5, 4 x 6, 5 x 7, 5 x 8, A4, A5, A6, RA4, B5 (JIS), B6 (JIS), L (90 x 130 mm), 10 x 15 cm, Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, Japanese Postcard (Postcard (JIS)), Double Japan Postcard Rotated (Double Postcard (JIS))
Face-down
Bottom edge leading into the printer
Portrait
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Letter, Legal, Executive, Oficio (8.5 x 13), A4, A5, RA4, B5 (JIS), Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm
Face-up
Landscape
1-sided printing
Face-down
Top edge toward the back of the printer
Landscape
Face-up
Prepunched paper
Image orientation
Duplex mode
Paper size
How to load paper
Portrait and landscape
1-sided printing
Holes toward the back of the printer
Use alternative letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus.
Enable Alternative Letterhead Mode by using the printer control-panel menus
  1. From the Home screen on the printer control panel, navigate to the Settings application, and then select the Settings icon.
  2. Open the following menus:
    1. Copy/Print or Print
    2. Manage Trays
    3. Alternative Letterhead Mode
  3. Select On.
