Document ID: c05493766
Version: 1
Advisory: HP Z220 Workstation - Upgrading to Windows 10 build 1507 May Result in IRST Application Error
Release date : 27-Apr-2017
Last updated : 27-Apr-2017
DESCRIPTION
Upgrading to the initial release of Windows 10 (build 1507, also called Threshold 1) and attempting to launch the Intel Rapid Storage Technology application, you may receive a message stating there was an issue launching the application. You may also receive a message stating the application needs to be reinstalled. This issue is resolved if the user reinstalls the application from the SoftPaq on HP.com
Symptoms:
The application will not launch, and an error prompting the user to reinstall the application will appear.
SCOPE
Systems:
  • HP Z220 Convertible Minitower Workstation
  • HP Z220 Small Form Factor Workstation
Operating Systems:
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 Enterprise (64-bit)
RESOLUTION
To resolve the issue, please go to the HP.com URL and enter your product under drivers and software. Once your platform is selected you will need to select the OS, Windows 10. Under Driver-Storage download the softpaq for Intel Rapid Storage Technology Utility and Driver for Microsoft Windows 10.
The specific revision for the Storage driver is 13.2.4.1000 Rev.A and the associated softpaq download is SP79789.
Hardware platforms affected : HP Z220 Convertible Minitower Workstation, HP Z220 Small Form Factor Workstation
Support Communication Cross Reference ID : IA05493766
