HP Notebook - 17-x103ur Product Specifications
1AP16EA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz with Intel® Turbo Boost Technology, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R5 M430 Graphics (2 GB DDR3 dedicated)
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal HD+ SVA BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.1; 1 RJ-45
41.7 x 27.9 x 2.49 cm
2.65 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
