Specification
Type
TN with LED backlight
Viewable image area
52.58 cm (20.7 in) widescreen; diagonally measured
Active area (W x H)
457.92 x 257.58 mm (18.02 x 10.14 in)
Aspect ratio
16:9
Viewing angle (typical CR>10)
90° horizontal
65° vertical
Brightness (typical)
200 cd/m2
Static contrast ratio
600:1 (typical)
450:1 (minimum)
Dynamic contrast ratio
5,000,000:1
note: |
Response rate (typical)
5 ms on/off (typical)
Pixel pitch
0.2385 x 0.2385 mm
Pixels per inch (PPI)
108
Backlight lamp life (to half brightness)
30,000 hours minimum
Default color temperature
Neutral (6500 K)
NTSC
72%
Panel bit depth
6-bit (Hi-FRC)
note:Actual performance varies.
