HP LaserJet Managed MFP - How to staple with an optional finisher accessory
If an optional stapler finisher accessory is installed on the printer, you can assemble and staple pages when printing or copying. The collate option assembles the pages in the correct order in each set of copies. You can collate and staple with the following types of optional accessories.
Inner Finisher
An Inner Finisher accessory fits inside the printer bin.
Stapler/Stacker Finisher or Booklet Finisher
A Stapler/Stacker Finisher accessory or a Booklet Finisher accessory attaches to the side of the printer.
Staple when copying from the document feeder
Follow these steps to collate and staple when copying from the automatic document feeder (ADF) optional accessory.
  1. Place the documents face-up in the document feeder and adjust the paper guides to fit.
  2. From the Home screen on the printer control panel, select Copy.
    Figure : Copy icon
  3. Select Options in the lower left corner.
  4. Select Staple in the Options list, and then select the desired stapling option from the Staple/Hole Punch menu.
  5. The collate option is on by default. To turn off the collate option, scroll down to the end of the Options menu, select Collate, and then select Off.
  6. Select any other settings needed from the Options menu, such as Sides and Content Orientation. Select Done if prompted.
  7. To adjust the number of copies, touch the box to the left of the Copy button, and then select the number of copies from the keypad that opens. Select the Close button to close the keypad.
  8. Select Copy to begin copying.
Staple when printing from Windows
Follow these steps to collate and staple when printing from a Windows application, using either an HP UPD print driver, or the HP PCL 6 or HP PCL-6 V4 printer-specific print driver.
Other print drivers might not support the collate/staple features provided by the printer accessory.
  1. From the software program, select the Print option.
  2. Select the printer from the list of printers, and then select the Properties or Preferences button to open the print driver.
  3. Select the Output tab, and from the Staple drop-down menu, select the position and number of staples.
  4. Select any other settings from the other tabs in the print driver.
  5. Select OK, and then select Print.
Staple when printing from OS X
Follow these steps to collate and staple when printing from an OS X application, using an HP print driver.
  1. In the application, select File, select Print, and then select the appropriate printer in the Printer drop-down menu.
  2. Just below Orientation, in the drop-down menu, select Finishing.
    The name of the item varies for different software programs.
  3. Select the Staple drop-down menu, and then select the position and number of staples.
  4. Select Print.
Staple with the exterior convenience stapler
The Stapler/Stacker Finisher and Booklet Finisher have a convenient exterior slot for stapling documents. To use the exterior stapler, align the documents and then insert them into the slot. Press the Staple button on the top of the finisher. The finisher staples the documents on the corner that you insert.
The printer must be awake (not in sleep mode) in order to use the exterior convenience stapler.
Figure : Exterior stapler on the finisher
Staple configurations and supported papers
HP staple accessories can produce several staple configurations. The output result depends on the supported paper size, document orientation, and feed orientation. (Feed orientation is the direction that you load the paper in the tray.)
Long edge feed orientation
Short edge feed orientation
Portrait document orientation
Landscape document orientation
The following tables show the output options for supported papers.
The following paper types do not support stapling:
  • Heavy envelope
  • Labels
  • Transparency
  • Envelope
  • User Types 1 to 10 (custom paper sizes added to the print driver via the HP Embedded Web Server or HP Web Jet Admin)
One staple – Long edge tray feed orientation
Supported papers
One staple left
One staple right
  • Letter
  • 216 x 279 (8.5 x 11 in)
  • A4
  • 210 x 297 mm (8.3 x 11.7)
Portrait
Landscape
One staple –Short edge tray feed orientation
Supported papers
One staple left
One staple right
  • Letter
  • A4
  • Ledger
  • 279 x 432 (11 x 17 in)
  • A3
  • 297 x 420 mm (11.7 x 16.5 in)
  • B4 (JIS)
  • 257 x 364 mm (10.1 x 14.3)
  • Legal
  • 216 x 356 mm (8.5 x 14.0)
  • Long Bond
  • 216 x 330 mm (8.5 x 13 in)
  • Oficio
  • 216 x 340 mm (8.5 x 13.4)
  • 8K
  • 270 x 390 mm (10.6 x 15.3)
Portrait
Landscape
Two staples– Long edge tray feed orientation
Supported papers
Two staples left or top
Two staples left
Two staples right
Two staples top
  • Letter
  • A4
Portrait
Not supported
Landscape
Not supported
Not supported
Two staples– Short edge tray feed orientation
Supported papers
Two staples top or left
Two staples left
Two staples right
Two staples top
  • Letter
  • A4
  • Ledger
  • A3
  • B4 (JIS)
  • Legal
  • Long Bond
  • Oficio
  • 8K
Portrait
Not supported
Not supported
Landscape
Not supported
