HP LaserJet Managed MFP E82540-E82560, HP Color LaserJet Managed MFP E87640-E87660 - Clear paper jams in Tray 2 and Tray 3 - 13.A2, 13.A3
Use the following procedure to check for paper in all possible jam locations related to Tray 2 or Tray 3. When a jam occurs, the control panel might display a message and an animation that assists in clearing the jam.
The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
The procedure to clear a paper jam in Tray 3 is the same as for Tray 2. Only Tray 2 is shown here.
  1. Open the right door.
    Figure : Open the door
  2. Gently remove any jammed paper.
    Figure : Remove the jammed paper
  3. Close the right door.
    Figure : Close the door
  4. Open the tray.
    Figure : Open the tray
  5. Gently remove any jammed paper.
  6. Close the tray. Printing automatically resumes.
    Figure : Close the tray
