    Apache Log4j Update
HP LaserJet Managed MFP E82540-E82560, E87640-E87660 - 13.B2.A1, 13.B2.D1 jam error in tray 1
Use the following procedure to clear a paper jam in tray 1. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.A1
  • 13.B2.D1 Jam in tray 1
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in tray 1:
  1. Gently remove the jammed paper from tray 1.
    Figure : Remove jammed paper from tray 1
  2. Open and then close the front door to resume printing.
