HP LaserJet Enterprise 500 Color MFP M575 - Optional Tray 3
Tray capacity and paper orientation
To prevent jams, do not overfill trays. Be sure the top of the stack is below the tray-full indicator. For short/narrow and heavy/glossy paper, load paper to less than half of the tray-full indicators.
Tray 3 capacity
Paper type
Quantity
Paper
Range:
60 g/m2 to 220 g/m2
Equivalent to 500 sheets of 75 g/m2
Maximum stack height: 56 mm
Labels
Maximum: 0.102 mm thick
Transparencies
Minimum: 0.102 mm thick
Glossy paper
Range:
105 g/m2 to 220 g/m2
Tray 3 paper orientation
Paper type
Image orientation
Duplex mode
How to load paper when Alternative Letterhead Mode is disabled
How to load paper when Alternative Letterhead Mode is enabled
Preprinted or letterhead
Portrait
1-sided printing
Face-up
Top edge at the right side of the tray
Face-up
2-sided printing
Face-down
Top edge at the left side of the tray
Face-down
Landscape
1-sided printing
Face-up
Top edge toward the back of the product
Face-up
2-sided printing
Face-down
Top edge toward the front of the product
Face-down
Prepunched
Portrait or landscape
1- or 2-sided printing
Holes toward the back of the product
Not applicable
Load Tray 3
This tray holds up to 500 sheets of 75 g/m2 paper. If the paper is heavier, the tray does not hold as many sheets. Do not overfill the tray.
Do not print envelopes, postcards, or unsupported sizes of paper from Tray 3. Print these types of paper only from Tray 1.
  1. Slide open the tray.
    Do not open the tray while it is in use.
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
  3. Load paper into the tray face-up. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure the top of the stack is below the tray–full indicator.
    If the tray is not adjusted correctly, an error message might display during printing or the paper might jam.
  4. Slide the tray into the product.
  5. The control panel shows the tray’s paper type and size. If the configuration is not correct, follow the instructions on the control panel to change the size or type.
  6. For custom-size paper, you need to specify the X and Y dimensions for the paper
Automatic paper sensing (auto-sense mode)
The automatic paper type sensor functions when a tray is configured to the Any Type or Plain setting.
After it has picked up paper from the tray, the product can detect overhead transparencies, paper weight, and gloss level.
For more control, select a specific paper type for the job or configure the tray for a specific paper type.
Auto-sense settings
Follow the steps below to configure the auto-sense settings.
The steps vary according to the type of control panel.
FutureSmart 3
FutureSmart 4
FutureSmart 3
  1. From the Home screen on the product control panel, scroll to and touch the Administration button.
  2. Open the following menus:
    • General Settings
    • Print Quality
    • Auto Sense Behavior
  3. Select one of the auto-sense modes.
    Expanded sensing
    This is the default setting for all trays.
    For the first few sheets of paper that it picks up from the tray, the product detects light paper, plain paper, heavy paper, glossy paper, tough paper, and transparencies. The product assumes the rest of the pages are of the same type.
    Transparency only
    The product distinguishes between transparencies and non-transparencies. This setting provides the fastest printing, but for some paper types it might reduce print quality.
FutureSmart 4
  1. From the Home screen on the printer control panel, select Settings.
  2. Select Copy/Print.
  3. Select Print Quality.
  4. Select Auto Sense Behavior.
  5. Select one of the auto-sense modes, and then touch Done to save the setting.
    Auto-sense mode
    Sense first page
    For the first sheet of paper that it picks up from the tray, the printer detects light paper, plain paper, heavy paper, glossy paper, tough paper, and transparencies. The printer assumes that the rest of the pages are of the same type.
    Sense transparency only
    The printer distinguishes between transparencies and non-transparencies. This setting provides the fastest printing, but for some paper types it might reduce print quality.
