HP 27b Curved Display - Product Specifications
The HP 27b is a 68.6 cm (27 in) curved display.
Figure : HP 27b Curved Display
The HP 27b Curved Display
1AT04AA
Technical specifications
LED feature
Specification
Display size
68.6 cm (27 in) diagonal
Panel active area
59.8 x 33.6 cm (23.6 x 13.2 in)
Aspect ratio
16:9
Display type
VA
Brightness
300 nits
Color gamut
sRGB 99% or above
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.3114 mm (H) x 0.3114 mm (W)
81.6 PPI
Inputs
1 HDMI
1 Display Port 1.2
1 audio output
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Scan range
Horizontal: 30-86 Khz
Vertical: 48-75 Hz
Resolution (recommended)
1920 x 1080 @ 60 Hz
Static contrast ratio
3000:1
Dynamic contrast ratio
10,000,000:1
Response time
5 ms GtG with overdrive
Power consumption
41.5 W max
Tilt
-5 to +13 degrees
Dimensions
W x D x H (unpacked):
61.5 x 18.0 x 43.9 cm (24.2 x 7.1 x 17.3 in)
Unpacked: 5.0 Kg (11.0 lbs)
Country: Flag Serbia
