Figure : HP Elite USB-C Dock
Specification
Dimensions (H x W x D)
197.87 x 68.83 x 22.10 mm (7.79 x 2.71 x 0.87 in)
0.355 kg (0.783 lbs)
Resolution
Single display
Up to 4096 x 2160 at 60 Hz
Dual display
Up to 2560 x 1600 at 60 Hz
Triple display
Up to 1920 x 1200 at 60 Hz
Front components
(1) USB 3.0 port1
(1) USB-C port1 (connects to other peripherals)
(1) Audio jack combo (connects to headphone)
(1) Hi-Res button with LED backlight (supports higher display resolutions)
Side/rear components
(1) Smart AC adapter
(1) Powered USB 3.0 port1
(2) USB 2.0 ports
(1) USB-C port2 (connects to computers)
(1) Gigabit Ethernet port1
(1) HDMI port
(2) DisplayPort (DP) ports
(1) Kensington lock slot
Normal operating power
90 W
Average operating power
65 W
Maximum operating power
100 W
Power Delivery (PD) profile
USB-C PD 3.0 supporting 5 V/3 A, 9 V/3 A,10 V/3 A, 12 V/3 A, 15 V/3 A and 20 V/3 A
Temperature (operating)
0° to 40° C (32° to 104° F)
Relative humidity (operating)
0 to 90%
Altitude (operating)
3,048 m (10,000 ft)
Shock (operating)
40 G, 2 ms duration, half-sine wave shock
Random vibration (operating)
1.043 grms
1USB ports operate at USB 2.0 speed and the Gigabit NIC functions at 10/100 speeds when the dock is in 4-lane DisplayPort mode.2Supports DisplayPort Alt Mode (video, charging, and USB 3.1) over the USB-C connector. Also compatible with USB Type-C Thunderbolt enabled ports.
Specification
Operating systems
Windows 10
Windows 10 Mobile
Specification
Package contents
HP Elite USB-C Dock
AC power cable
90 W AC Adapter
USB-C cable, 1 m (3.28 ft)
Documentation
