HP ENVY - 13-ab065tu Product Specifications
1HQ04PA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
4 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® HD Graphics 620
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal QHD+ UWVA eDP BrightView WLED-backlit multitouch-enabled edge-to-edge glass (3200 x 1800)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 microSD media card reader
1 HDMI; 1 headphone/microphone combo; 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1
32.6 x 22.6 x 1.39 cm
1.39 kg
45 W AC power adapter
3-cell, 57.8 Wh Li-ion
HP TrueVision HD Camera with dual array digital microphone
Bang & Olufsen; Dual speakers
HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect
Pre-installed software
CyberLink PowerDirector; User Guide documentation; Dropbox; CyberLink Power Media Player
Buy Office
