1HP27PA
OMEN by HP - 17-w241tx
Intel® Core™ i7-7700HQ (2.8 GHz, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1070 (8 GB GDDR5 dedicated)
17.3" diagonal UHD IPS UWVA anti-glare WLED-backlit (3840 x 2160)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone-out; 1 microphone-in; 1 USB 2.0; 2 USB 3.1 Gen 1; 1 RJ-45
41.6 x 27.9 x 3.29 cm
3.35 kg
230 W AC power adapter
6-cell, 95.8 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP - 17-w241tx Product Specifications
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
