Product Specifications for the HP LaserJet Pro M230sdn Printer (G3Q76A)
Product naming
Model name
HP LaserJet Ultra MFP M230sdn
G3Q76A
What's included and accessories
What's in the box
HP LaserJet Pro MFP M230sdn; HP Black LaserJet Toner Cartridge; HP LaserJet Imaging Drum; Power cord; USB cable (Asia Pacific countries/region only); Getting started guide; Set up poster; Support flyer; Warranty documents (some countries); Printer documentation and software on CD-ROM; Errata, declaration (some countries)
Connectivity
Ports
1 Hi-Speed USB 2.0; 1Ethernet 10/100network
Storage device and direct print support
USB printing
Copy
Copier settings
Number of Copies; Lighter/Darker; Optimize; Paper; Multi-Page Copy; Collation; Draft Mode
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 30 cpm
Copy resolution
600 x 600 dpi
Environmental
Acoustic power emissions
6.6 B(A) (printing at 28 ppm)
Operating humidity range
30 to 70% RH
Storage humidity
10 to 90% RH
Recommended operating temperature range (Celsius)
17.5 to 25ºC
Storage temperature range (Celsius)
-20 to 60ºC
Environmental specifications
Mercury free
Memory
Memory, maximum
256 MB
Mobile printing capability
Mobile printing services
HP ePrint; AirPrint; Google Cloud Print 2.0
Mobile printing compatibility note
HP ePrint - App or software and HP ePrint account registration may also be required. Some features require purchase of an optional accessory. Learn more at http://www.hp.com/go/mobileprinting. Apple Airprint -Mobile device must have iOS v7.0 or higher. Learn more at http://www.hp.com/go/mobileprinting. Google Cloud Print™ 2.0 - Requires Google Cloud Print™ registration and Google account. Learn more at http://www.hp.com/go/mobileprinting
Networking
Network protocols, supported
TCP/IP: IPv4; IPv6; IP Direct Mode; LPD; SLP; Bonjour; WS-Discovery; BOOTP/ DHCP/ AutoIP; WINS; SNMP v 1/2/3; and HTTP/HTTPS
Paper handling
Input capacity
Up to 260 sheets
Output capacity
Up to 150 sheets
Media sizes supported (metric)
A4; A5; B5 (JIS); A6
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media types
Paper (laser, plain, photo, rough, vellum), envelopes, labels, cardstock, postcards
Media weight supported (metric)
60 to 163 g/m²
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Media size (ADF)
A4; Letter; Legal
Media weight supported, ADF (metric)
70 to 90 g/m²
Media type and capacity, ADF
35 sheet of 20 lb plain paper
Paper handling - duplexer
Recommended media weight, duplex (metric)
60 to 105 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
403 x 624.4 x 455.6 mm
Weight (metric)
10 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal
Power supply
110-volt input voltage: 110 to 127 VAC (+/- 10%), 60 Hz/50 Hz, 5.9 A; 220-volt input voltage: 220 to 240 VAC (+/- 10%), 60 Hz/50 Hz, 3.3 A
Power consumption
475 watts (active printing), 4.5 watts (ready), 1.0 watts (sleep), 0.8 watts (Auto Off/Wake on USB, enabled at shipment)
Power consumption footnote
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the product warranty. Power consumption values typicallty based on measurement of 115 V device.
Print cartridges
Number of print cartridges
3 Black
Replacement cartridges
HP 31A Original Black LaserJet Toner Cartridge CF231A; HP 32A Original LaserJet Imaging Drum CF232A
Replacement cartridges footnote
Declared yield value in accordance with ISO/IEC 19752. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. For more information, visit http://www.hp.com/go/SureSupply; only available with Original HP supplies; Internet access required.
Printing specifications
Print technology
Laser
Duplex printing
Automatic (standard)
Print resolution (best)
Up to 1200 x 1200 dpi
Maximum print area (metric)
206 x 348 mm
Monthly duty cycle
Up to 40,000 pages
Print languages
PCL5c; PCL6; PS; PCLmS; PDF; URF; PWG
Printer smart software features
AirPrint, Instant-on Technology, HP Auto-On/Auto-Off Technology, JetIntelligence cartridges,Duplex printing
Regulatory specifications
Regulatory model number
SHNGC-1503-00
Safety
IEC 60950-1:2005 +A1:2009+A2:2013/EN60950-1:2006 +A11:2009 +A1:2010+A12:2011+A2:2013; IEC 60825-1:2007 / EN 60825-1:2007 (Class 1 Laser/LED Product); IEC 62479:2010 / EN 62479:2010; GB4943-2011
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 - Class B, EN 61000-3-2:2006 +A1:2009 +A2:2009, EN 61000-3-3:2013, EN 55024:2010, FCC Title 47 CFR, Part 15 Class B / ICES-003, Issue 6, GB9254-2008, GB17625.1-2012
Scan
Scan technology
CIS
Scan speed (normal)
Up to 12 ppm
Scan speed footnote
Scan speeds measured from ADF.  Actual processing speeds may vary depending on scan resolution, network conditions, computer performance, and application software.
Scan resolution, hardware
Up to 300 x 300 dpi (color and mono, ADF); Up to 1200 x 1200 dpi (color and mono, flatbed)
Levels of grayscale
256
Bit depth
24-bit
Duplex ADF scanning
No
Maximum flatbed scan size (metric)
215.9 x 297 mm
Minimum ADF scan size (metric)
148.5 x 210 mm
Maximum ADF scan size (metric)
215.9 x 355.6 mm
Twain version
Version 1.9 (Legacy OS); Version 2.1 (Windows 7 or higher)
Security
Security management
Password-protected network embedded Web server; enable/disable Network ports; SNMPv1 community password change; 802.1x authentication
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8
Minimum system requirements for Macintosh
Apple OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite ): 1 GB available hard disk space; Internet required; USB
Compatible network operating systems
Windows 10, 8, 7 (32-bit or 64-bit): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista (32-bit only): 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Apple OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite ): 1 GB available hard disk space; Internet required; USB. Linux (For more information, see http://hplipopensource.com/hplip-web/index.html). Unix (For more information, see http://www.hp.com/go/unixmodelscripts)
Operating system (supported note)
Not supporting Windows XP (64-bit) and Windows Vista (64-bit). Not all "Compatible Operating Systems" are supported with INBOX software; Full solution software available only for Windows 7 and newer; Legacy Windows Operation Systems (XP, Vista, and equivalent servers) get print drivers only; For Windows Server 2003 32-bit and 2008 32-bit and 64-bit, 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit only print driver is installed. Windows RT OS for Tablets (32 & 64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software
1 Year Limited Warranty
