HP Notebook - 15-ba028AX Product Specifications
Z4Q68PA
AMD Quad-Core A8-7410 APU (2.2 GHz, up to 2.5 GHz, 2 MB cache)
Flash cache
39.6 cm (15.6) HD SVA display
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ R5 M430 Graphics (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6) diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
38.43 x 25.46 x 2.43 cm
2.19 kg
65 W EM AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers; DTS Studio Sound™
HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
MS Office
