    We are upgrading our website
HP Pavilion - 15-au636tx Product Specifications
Z6X70PA
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1; 1 RJ-45
38.3 x 24.3 x 2.25 cm
Starting at 2.03 kg
65 W EM AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Dual speakers; B&O PLAY
FreeDOS 2.0
