HP ENVY - 15-as130nd Product Specifications
Y5U58EA
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz, 4 MB cache, 2 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
Intel® HD Graphics 620
  • 1 TB 5400 rpm SATA
  • 256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS UWVA multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 3 USB 3.1 Gen 1 (1 HP Sleep and Charge) ; 1 USB 3.1 Type-C™ Gen 1
38 x 25.5 x 1.79 cm
2.13 kg
45 W AC power adapter
3-cell, 52 Wh Li-ion
HP TrueVision HD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
1 month trial for new Microsoft® Office 365 customers
