    Fix HP Printer issue on macOS
HP ProDisplay P223a 21.5-inch Monitor - Overview
Figure : HP ProDisplay P223a 21.5-inch Monitor
Product features
Specification
Model
X7R62AA
Type
21.5-inch VA with LED backlight
54.61 cm (21.5-inch) widescreen
Active area (W x H)
47.6 x 26.7 cm (18.74 × 10.51 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal
Up to 178° vertical
Brightness
250 cd/m2
Dynamic contrast ratio (typical)
3000:1 static
5,000,000:1 dynamic (DCR)
Response time (typical)
5 ms typical (gray to gray)
Pixel pitch
0.248 mm (0.039 in)
Pixel pitch inch (PPI)
260.1 cm (102.4 in)
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
