    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
CSR Part Return Instructions - Europe, Middle East, and Africa
Important: Do not discard your defective part. This part must be returned to HP within 5 calendar days of when you received the replacement part. (Return is free of charge, prepaid by HP.)
  1. Check for a return label. If your defective part needs to be returned, HP will provide return labels either inside the box, or in the "poly pouch" attached to the box. Spare part shipments contain detailed instructions on how to return the defective part.
  2. Package the part carefully using the packaging material that came with the new part.
  3. Seal the box with packaging tape.
  4. Apply the return label to the box, covering up the original shipping label.
  5. To arrange for prepaid package return, follow the detailed instructions included in the spare part shipment.
  6. If you have additional questions, please Contact HP.
Additionally, the CSR E-Notification shipment confirmation e-mail contains a link to detailed returns instructions in your local language.
