    We are upgrading our website
Remove and Replace the Display Panel on HP ProBook 640 and 645 G2 Notebooks
This document applies to HP ProBook 640 and 645 G2 notebooks.
HP ProBook 64x G2 notebook
Before you begin
  • Have available a small Phillips-head (P1) screwdriver, a small flat-bladed alignment/pry tool, and tweezers or pliers.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing, replacing, and/or servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risks and refer to the product's warranty before attempting to service the computer.
Removing the display panel
Use the steps in this section to remove the display panel.
Step 1
Remove the bottom cover.
The bottom cover
Step 2
Remove the battery.
The battery
Step 3
Remove the display bezel.
The display bezel
Step 4
Remove the four 3 mm P1 Phillips-head screws that secure the display panel to the display enclosure.
Make careful note of the routing of the display panel cable for later replacement.
Removing the four screws
Step 5
Lift the display panel off of its alignment pins...
To prevent damage, do not rest the display panel on its lower edge.
Take care not to scratch the display panel screen or top cover.
Lifting the display off the alignment pins
...and place it face down on the top cover.
Step 6
Peel back the retention tape that secures the display panel cable to the display panel
Peeling back the retention tape
...and disconnect the display panel cable from its connector on the display panel.
Disconnecting the display panel cable
Step 7
Remove the display panel.
Replacing the display panel
Use the steps in this section to replace the display panel.
Step 1
Place the display panel face down on the top cover.
Placing the display panel down on top cover
Step 2
Connect the display panel cable into its connector on the display panel ...
Connecting the display panel cable
...and replace the retention tape
Replacing the retention tape
Step 3
Lift the display panel and place it onto its alignment pins on the display enclosure.
Lifting the display panel
Step 4
Replace the four 3 mm P1 Phillips-head screws that secure the display panel to the display enclosure.
Replacing the screws
Step 5
Route the display panel cable through the routing channel on the display enclosure.
The display panel cable
Step 6
Replace the display bezel.
The display bezel
Step 7
Replace the battery.
The battery
Step 8
Replace the bottom cover.
The bottom cover
