    Fix Windows 10 Update Issues
HP Printers - Printing with Amazon Alexa
This document is for HP web-connected printers, the Amazon Alexa app, and Alexa-supported devices, such as an Echo or Fire Tablet.
Enable the HP Printer skill from the Amazon Alexa app on your mobile device or computer to ask any Alexa-supported device to print your custom lists, shopping and to-do lists, and pre-formatted documents, such as puzzles, calendars, checklists, comics, and coloring pages.
You can also print from other skills using Alexa Skill Connections, such as Allrecipes (United States only).
Step 1: Enable the HP Printer skill
Enable the HP Printer skill and add a printer from your HP account.
Refer to these frequently asked questions for more information about printing from an Amazon Alexa device.
