HP ENVY x360 - 15-aq160sa Product Specifications
Z3B63EA
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz, 4 MB cache, 2 cores)
8 GB DDR4-1866 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 620
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 3.1 (1 HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1
38 x 25 x 1.88 cm
2.17 kg
45 W AC power adapter
4-cell, 55.67 Wh Li-ion
HP TrueVision HD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Lounge
Pre-installed software
CyberLink PowerDirector; Netflix
1 month trial for new Microsoft® Office 365 customers
