Use the following procedure to clear jams in the output bin. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
13.E1.yz
13.E6.Az
13.E6.Bz
If paper is visible from the output bin, grasp the leading edge and remove it.Figure : Remove jammed paper from the output bin
