    Apache Log4j Update
HP Notebook - 15-ay538ur Product Specifications
Z4Z90EA
Intel® Pentium® N3710 (1.6 GHz, up to 2.56 GHz, 2 MB cache, 4 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R5 M430 Graphics (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
38.43 x 25.46 x 2.43 cm
2.04 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
