    Apache Log4j Update
HP Pavilion 17-ab020nr (Touch) (ENERGY STAR) Product Specifications
W2L97UA
Intel® Core™ i7-6700HQ (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
12 GB DDR4-2133 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • NVIDIA® GeForce® GTX 960M (4 GB GDDR5 dedicated)
  • Discrete
  • 1 TB 7200 rpm SATA
  • [13]
Optical drive
SuperMulti DVD burner
17.3" diagonal FHD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel 802.11ac (2x2) and Bluetooth® 4.0 Combo
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.0
120 W AC power adapter
6-cell, 62 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP 3D DriveGuard; HP CoolSense; HP ePrint; HP Games by WildTangent; HP Recovery Manager; HP Support Assistant
Pre-installed software
CyberLink Power Media Player; CyberLink PowerDirector; Dropbox; Netflix
