    Apache Log4j Update
HP Notebook - 15-ba051wm (Touch) (ENERGY STAR) Product Specifications
Y0H39UA
AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
8 GB DDR4-2133 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon R5 Graphics (up to 4.25 GB)
  • 1 TB 5400 rpm SATA
  • [10]
Optical drive
SuperMulti DVD burner
15.6" diagonal HD SVA WLED-backlit touch screen (1366 x 768)
Keyboard
Full-size island-style with numeric keypad
Pointing device
802.11b/g/n (1x1) (Miracast compatible)
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.43 x 25.46 x 2.43 cm
2.15 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP ePrint; HP Games by WildTangent; HP Support Assistant; HP Connected Photo
Pre-installed software
Netflix; Dropbox; CyberLink Power Media Player; CyberLink PowerDirector; TripAdvisor; VUDU
