    Apache Log4j Update
HP Notebook - 17-y043ng Product Specifications
Y6H51EA
AMD Quad-Core A8-7410 APU (2.2 GHz, up to 2.5 GHz, 2 MB cache)
8 GB DDR3L-1600 SDRAM (1 x 8 GB)
Video graphics
  • AMD Radeon™ R5 Graphics
  • Integrated
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD+ SVA anti-glare WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
41.7 x 27.9 x 2.49 cm
2.65 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
