HP HC240 24-inch Healthcare Edition Display - Specifications
Panel
Specification
Type
60.96 cm (24 in) diagonal IPS with LED backlight
60.96 cm (24 in) widescreen
Panel active area (W × H)
51.84 x 32.4 cm (20.41 × 12.76 in)
Resolution
1920 x 1200 at 60 Hz
Aspect ratio
16:10
Viewing angle
Up to 178° horizontal/178° vertical typical
Brightness
300 cd/m2
Contrast ratio (typical)
1000:1 static; 5,000,000:1 dynamic (DCR)
Response times*
8 ms typical (G-to-G)
Pixel pitch
0.270 mm
Pixels per inch (PPI)
94.3 dots per inch
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
99% sRGB
Default color setting
DICOM
Actual performance might vary.
User controls
Specification
Buttons or switches
Menu
Luminance
Color control
Input control
User programmable modes
10
Languages
10 (English, French, German, Italian, Japanese, Dutch, Portuguese, Spanish, Traditional Chinese and Simplified Chinese)
On screen display (OSD) user controls
Luminance, color control, input control, image control, PIP control, power control, OSD control, management, language, information
Signal interface/performance
Specification
Horizontal frequency
30 - 75 kHz
Vertical frequency
50 - 60 Hz
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input/output connectors
(1) DVI-D
(1) MHL 2.0/HDMI 1.4
MHL 2.0 port will charge an MHL-compatible smart phone/tablet battery. Requires the smart phone or tablet to be enabled for MHL or have an HDMI dongle to connect to the monitor.
(1) DisplayPort 1.2
(1) DisplayPort 1.2 out
(1) Mini-DisplayPort
USB
(5) USB 3.0, (4) downstream (1 fast charging), (1) upstream
HDCP support
Yes, on all inputs
Video cables included
(1) DisplayPort, 1.8 m (5.9 ft)
(1) HDMI, 1.8 m (5.9 ft)
(1) USB 3.0, 1.8 m (5.9 ft)
Audio
(1) Audio output 3.5 mm (.14 in)
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
70 W
Typical power
36 W
Sleep power
0.5 W (standby)
Power cable length
1.8 m (5.9 ft)
Mechanical
Specification
Dimensions (W × D × H)
Head only
53.38 x 4.93 x 35.11 cm (21.02 x 1.94 x 13.82 in)
With stand
53.38 x 21.01 x 52.02 cm (21.02 x 8.27 x 20.48 in) maximum height
Packaged
63.2 x 25.0 x 44.0 cm (24.88 x 9.84 x 17.32 in)
Head Only
3.87 kg (8.53 lbs)
With stand
5.78 kg (12.74 lbs)
Packaged
7.61 kg (16.78 lbs)
Ergonomic features
Specification
Detachable stand
Yes
Height adjustment
130, +/-3 mm (.12 in)
Tilt range
-5° to 22° vertical
Swivel
45° (+/-2°) clockwise/counterclockwise
Pivot
90°
Quick Release
HP QR2 quick release included
The HP Quick Release has been designed to support a maximum of up to 10.9 kg (24 lbs) for all devices mounted. Mounting fasteners are not supplied (other than the VESA-compliant screws). HP recommends that you consult with a qualified engineering, architectural or construction professional to determine the appropriate type and quantity of mounting fasteners required for your application and to ensure that your mounting solution is properly installed to support applied loads.
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C (101.66° F) max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes (except cables)
Mercury-free display backlighting
Yes
What's in the box?
Specification
Monitor and accessories
HP HC240 Healthcare Edition display
(1) AC power cord, 1.8 m (5.9 ft)
(1) DisplayPort cable, 1.8 m (5.9 ft)
(1) HDMI cable, 1.8 m (5.9 ft)
(1) USB 3.0 cable, 1.8 m (5.9 ft)
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
Miscellaneous
Specification
User guide languages
Arabic, Brazilian Portuguese, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Russian, Slovenian, Spanish, Swedish, Turkish, Traditional Chinese and Simplified Chinese
Warranty languages
Color
White
VESA mounting
100 mm (3.94 in) VESA mount
Security lock ready
Yes
Certification and compliance
ENERGY STAR Qualified, EPEAT Gold
EPEAT registration varies by country/region.
Safety: CB, TUV/GS, TUV/Ergo, TUV-S, UL, TCO Certified, TCO Certified EDGE, CCC, CECP, CEL, SEPA, BSMI, DICOM Part14, NFPA 99 certification for EMI: CE, FCC (Canada), BSMI, KC, VCCI, C-Tick
Microsoft WHQL Certification (Windows 10, Windows 8, and Windows 7); SmartWay Transport Partnership (NA)
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
