    We are upgrading our website
HP Pavilion - 14-al106tx Product Specifications
X9K45PA
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz, 4 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
  • NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
14" diagonal FHD IPS UWVA BrightView WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1; 1 RJ-45
33.86 x 22.43 x 1.95 cm
1.58 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
