    Windows 11 Upgrade Guide
HP 27ea 27-inch IPS Display - Product Specifications
The HP 27ea is a 68.6 cm (27 in) IPS Display.
Figure : HP 27ea IPS Display
The HP 27ea IPS Display
X6W32AA
Technical specifications
LED feature
Specification
Display size
68.6 cm (27 in) diagonal
Display type
IPS with LED backlight
Panel active area
59.8 x 33.6 cm (23.5 x 13.2 in)
Scan range
Horizontal: 30 to 80 KHz
Vertical: 50 to 60 Hz
Brightness
250 nits
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut
72%
Pixel pitch
0.3114 (H) mm x 0.3114 (V) mm
82 PPI
Inputs
1 VGA
2 HDMI
Audio in/Audio out
HDCP support
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz (Full HD)
Aspect ratio
16:9
Static contrast ratio
1000:1
Dynamic contrast ratio
10,000,000:1
Response time
6 ms GtG w/OD
14 ms GtG (typ) / 28 ms GtG (Max)
Power supply
External
Power consumption
30 Watts max
Tilt
-5 to +25 degrees
Dimensions
W x D x H (unpacked):
62.2 x 19.6 x 45.5 cm (24.5 x 7.7 x 17.9 in)
Unpacked: 3.9 Kg (8.6 lbs)
