HP LaserJet Pro, Ultra M203-M206 Printers - First Time Printer Setup
This document is for HP LaserJet Pro M203d, M203dn, M203dw, and LaserJet Ultra M206dn printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, load paper into the input tray, connect the power cable, remove the protective film from the control panel, and then download and install the printer software.
If you are looking for the printer software, go to 123.hp.com/laserjet.
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
The toner cartridge comes preinstalled in your printer. You do not need to remove the toner cartridge from the printer.
  2. Remove all tape and packing materials from the outside of the printer, and then remove the protective film from the printer control panel.
  3. Recycle the packing materials.
Step 2: Load paper into the main input tray
Load plain paper in the main input tray.
  1. Lower the main input tray door, and then slide out the paper width guides as far as possible.
    Figure : Sliding out the paper guides
  2. Load up to 250 sheets of paper with the print side facing up and the top edge toward the printer. If you are loading pre-punched paper, load the paper with the holes toward the left side of the tray.
    Figure : Loading plain paper in the main input tray
  3. Slide in the paper guides until they touch the edge of the stack of paper.
    Do not push in the guides so tightly that they bind against the paper.
    Figure : Sliding in the paper guides
  4. Press down on the output bin extension to open it, and then lower the output bin extender.
    • If you loaded A4 or U.S. letter-size paper, close the main input tray door.
    • If you loaded U.S. legal-size or larger paper, do not close the main input tray door.
    Figure : Lowering the output bin extender
    Before printing, select the correct paper size and paper type settings from the control panel or computer.
Step 3: Connect the power cord, and then turn on the printer
Plug the printer into a wall outlet, and then turn on the printer.
    Figure : Connecting the power cord
  2. Turn on the printer.
    The printer initializes and then calibrates itself.
  3. Wait until the printer is idle and silent before you proceed.
    Your HP printer hardware is now set up and you can install the printing software.
Step 4: Install the printer software
Download the latest version of the printing software from 123.hp.com/laserjet, and then follow the on-screen instructions to install the software.
