HP Pavilion x360 13-u033tu Product Specifications
X1G50PA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 520
1 TB 5400 rpm SATA
13.3" diagonal FHD IPS UWVA WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
1 USB 2.0; 2 USB 3.0; 1 HDMI; 1 headphone/microphone combo
32.64 x 22.2 x 1.98 cm
Starting at 1.58 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; User Guide documentation; Dropbox; TripAdvisor; CyberLink Power Media Player
Buy Office
