Document ID: c05216080
Version: 1
Advisory: HP EliteBook Revolve 810 G1 Convertible Tablet - Cannot Install HP GPS Location Software Version 2.0.2.1 or Later
Release date : 28-Jul-2016
Last updated : 28-Jul-2016
DESCRIPTION
When attempting to install HP GPS and Location Software, the installation fails and the following message is displayed:
HP GPS and Location cannot find any supported GPS device on this system
SCOPE
Computers:
Configuration:
Uses HP un2430 Mobile Broadband card
Operating Systems:
Microsoft Windows 7 Professional (64-bit)
RESOLUTION
HP GPS and Loaction Software versions 2.0.2.1 (and later) are not supported for use with the HP un2430 mobile broadband card installed in the EliteBook Revolve 810 G1. This card only supports version 1.3.4.1 of the software:
SoftPaq Description
Release Notes
Download SoftPaq
Version: 1.3.4.1
Revision: A
Hardware platforms affected : HP EliteBook Revolve 810 G1 Tablet
Support Communication Cross Reference ID : IA05216080
