    Apache Log4j Update
HP ENVY Notebook 15-as005tu Product Specifications
X0G66PA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
1 TB 5400 rpm SATA
15.6" diagonal FHD BrightView LED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible); WiDi
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (1 HP USB Boost); 1 USB 3.0 (Type-C™)
38 x 25.5 x 1.79 cm
1.96 kg
45 W AC power adapter
3-cell, 52 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Documentation
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; Dropbox; TripAdvisor
