    Apache Log4j Update
HP Notebook - 17-x061nr (ENERGY STAR) Product Specifications
W2M99UA
Intel® Core™ i3-5005U (2 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
  • Intel HD Graphics 5500
  • Integrated
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD + SVA BrightView WLED-backlit (1600 x 900)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
41.7 x 27.9 x 2.49 cm
2.65 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
DTS Studio Sound™; Dual speakers
