X5Q64PA
OMEN by HP Laptop PC - 15-ax028tx
Intel® Core™ i5-6300HQ (2.3 GHz, up to 3.2 GHz, 6 MB cache, 4 cores)
Intel HM170
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
NVIDIA® GeForce® GTX 960M (4 GB GDDR5 dedicated)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD UWVA eDP anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
WiDi; Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.2 x 25.3 x 2.45 cm
Starting at 2.03 kg
120 W AC power adapter
3-cell, 61.5 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
OMEN by HP Laptop PC - 15-ax028tx Product Specifications
HP Recovery Manager; HP Support Assistant; HP 3D DriveGuard; HP Documentation; HP ePrint
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
