HP Notebook - 15-ay049tu Product Specifications
X1F69PA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
38.43 x 25.46 x 2.43 cm
Starting at 2.19 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
DTS Studio Sound™; Dual speakers
HP ePrint; HP Recovery Manager; HP Support Assistant
